Joseph F
#1 Posted : Wednesday, March 11, 2009 2:18:46 PM(UTC)
Joseph F
Our GE Monogram 5 burner gas cook top has developed a problem with the ignitors. The large, front right burner will ignite, but the ignitor keeps sparking. Also, the ignitors of the two adjacent small burners will spark also, at the same time, even though only the front burner is lit.
Please advise the best course of action to correct. I understand that there are several components in the ignitor circuit. (spark module, spark ignitor switches, and the ignitor located in the burner)
Thanks for your help
J.F.
#2 Posted : Thursday, March 12, 2009 8:46:59 PM(UTC)
Joseph,
Remove the burner cap from the front right burner and inspect the burner igniter. The metal part of the igniter should not be bend and should be point to the center of the burner. If it's not then the igniter has to be replaced. Also the burner itself and the burner cap should be completely dry.
- The part number for the burner igniter is AP2020590
If the igniter has to be replaced be careful not to damage the igniter mounting clip because this part is no longer available.
Pull up the knob for the front right burner and check the switch cam. The middle hole can be worn out.
Here are the break down diagrams and Replacement parts for GE ZGU660ES3BG | AppliancePartsPros.com
P.S. All burner igniters are on the same circuit what means they all will spark together when any of the knobs has been turned "on".
Joseph F
#3 Posted : Friday, March 13, 2009 2:34:34 AM(UTC)
Joseph F
Gene,
Thanks for the advice. I'll try the igniter replacement tomorrow.
Joseph F
#4 Posted : Friday, March 13, 2009 11:27:02 AM(UTC)
TMuzzio
#5 Posted : Friday, October 16, 2009 5:19:48 PM(UTC)
TMuzzio
I have purchased the ignitor, but I do not see how to remove/replace it. wherre can I find instructions? Reminder. This is a
GE Monogram stove model ZGU660 ES3BG
#6 Posted : Saturday, October 17, 2009 4:26:20 PM(UTC)
If the top metal part of the igniter is not moving inside the ceramic insulation, pointed to the center of the burner and ceramic is not cracked then most likely there is nothing wrong with the igniter. Check all the igniters. Make sure the burners and the burner caps are clean and dry, and all caps are in the correct position. Post the results.
Here are the breakdown diagrams and Replacement parts for GE ZGU660ES3BG | AppliancePartsPros.com
TMuzzio
#7 Posted : Sunday, October 18, 2009 1:28:09 PM(UTC)
TMuzzio
I checked all the ignitors. The one on the front, right burner is loose. I have a new ignitor, but cannot find a way to gain access to it. How do I gain access to the ignitor?
Thank you for your assitance.
#8 Posted : Monday, October 19, 2009 3:31:23 PM(UTC)
You have to remove the cook top from the counter, turn it upside down, remove the screws holding the bottom panel and remove the panel.
Guest (4)
