dino55
#1 Posted : Friday, October 16, 2009 2:11:12 PM(UTC)
dino55
looking for some help made some repairs still freezing up in freezer:)
dino55
#2 Posted : Friday, October 16, 2009 2:42:29 PM(UTC)
dino55
looking for some help i replaced timer,
#3 Posted : Friday, October 16, 2009 4:07:46 PM(UTC)
Replacement parts for AMANA ARS2667BC | AppliancePartsPros.com
Rotate the timer cam till the evaporator and compressor fans shut off.
You are now in a defrost cycle.
Check to see if the defrost heater comes on.
Be careful do not burn your fingers
If yes you probably have a defective timer.
If no it is probably either
A. The defrost heater should be around 20 ohms
B. The defrost thermostat should be 0 ohms when frozen. Note it opens just above freezing.
Here are a couple good sites with basic fridge repair info.
http://www.applianceaid.com/refrigerator.html
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
