DAVID PRUDEN
#1 Posted : Monday, February 4, 2008 5:20:37 AM(UTC)
DAVID PRUDEN
STUCK IN DRAIN CYCLE NO MATTER WHICH CYCLE BUTTONS ARE PUSHED -ALSO SEEMS TO HAVE TEMPORARILY OVERFLOWED ENOUGH TO TOTALLY SOAK THE LOWER DOOR INSULATION:confused:
#2 Posted : Monday, February 4, 2008 1:24:31 PM(UTC)
Hi David,
Most likely there is a water leak somewhere in the dishwasher.
Remove the bottom panel and check for water in the base of the dishwasher.
Here are the break down diagrams for the Bosch dishwasher Model SHU9922 UC/12 (FD 8003-)
kawfeeman
#3 Posted : Tuesday, February 5, 2008 5:42:48 AM(UTC)
kawfeeman
will the d/w continue to run with the door open ?
