manthony4563
#1 Posted : Friday, October 16, 2009 9:46:11 AM(UTC)
manthony4563
The dryer would not heat. Heating element tested ok. Replaced the two thermostats and now is heating. But there is a yellow wire right up front with a white end cap that I don't remember disconnecting. Is it important and where does it go?
SublimeMasterJW
#2 Posted : Friday, October 16, 2009 11:15:47 AM(UTC)
SublimeMasterJW
Look inside the dryer below the filter. Their is some sensors mounted there. That yellow wire connects to the sensor and relays dampness info back up top. Page 7 of this tech sheet shows the sensors
Tech sheet
This tech sheet probably ain't yours but it does show features like yours :D
manthony4563
#3 Posted : Friday, October 16, 2009 12:30:51 PM(UTC)
manthony4563
Thanks, I found out where it goes. The previous repairman didn,t even reconnect it when he changed my heating element. Thanks alot
