dab830
#1 Posted : Thursday, October 15, 2009 10:08:18 AM(UTC)
dab830
just replaced the white control panel. Power to clock and controls (and top light) would go off when oven light goes off - either by turning off oven light switch or closing the oven door. I unplugged it for a while and upon re-plugging, it now reads locked. The only controls that work (when the oven light is on) are the clock and clean (although cleaning won't continue since the door is open and everything goes off if I close the door
dab830
#2 Posted : Thursday, October 15, 2009 2:27:47 PM(UTC)
dab830
it was a loose 9-pin connector plug about half way up on the back of the stove/oven.
