PERFORMA
#1 Posted : Monday, October 12, 2009 6:59:18 AM(UTC)
PERFORMA
My Washer Started To Get Hung Up On Rinse Cycle For A Couple Of Months But All I Had To Do Was Change It To Spin And It Was Fine. Now It Is Getting Hung Up On Every Cycle And When I Put It On Wash Or The Minutes Cycle Th Washer Fills Up But Never Goes Into Wash Mode And Agitate, It Just Fills Up And Drains Again. Is This A Timer Problem Or Fill Switch Maybe? Thanks Tim
sidfink43
#2 Posted : Wednesday, October 14, 2009 5:09:38 AM(UTC)
sidfink43
It sounds more like a timer problem, but I would check out the lid switch as a first thing. You can access it by releasing the clips that hold the top to the cabinet by inserting a screw driver or putty knife in the gap between the front and the top near the edges. The top will now flip up and give you access to the lid switch.
If it is ok then the timer is the next most likely suspect.
