Oven always lights the first time. Sometimes we will notice during the cycle that it has shut off (Failed to reignite?). If you turn the temp dial down and them right back up it will always ignite and proceed to bake.
I replaced the igniter and that fixed it for a couple months. Then it started happening again...I replaced the igniter again but the problem came right back in a couple days.
Help??
Groups: Senior Expert, Administrators Joined: 7/19/2007(UTC) Views messages in topic : 27,455
Most likely the problem caused by the oven thermostat which has to be replaced. - The part number for the oven thermostat is AP2633815 Here are the break down diagrams for the Hotpoint range Model RGB745GEV3ADGene.
