ccrice2222
#1 Posted : Monday, October 12, 2009 2:27:20 PM(UTC)
ccrice2222
Timer stops timing with 5-8 minutes left in dry cycle while in auto cycles. It seems to work fine in manual/timed dry cycle
sidfink43
#2 Posted : Tuesday, October 13, 2009 3:42:14 PM(UTC)
sidfink43
Here is the service manual which will take you through the trouble shooting on the moisture sensor bars to diagnose your problem.
https://secured.whirlpoo...61e709/$FILE/8178559.pdf
Here is the sensor wiring harness if that proves to be the problem.
Part number: AP3083393
