The control panel display went out. It still beeps when a button is pressed, but no display.
What do you think the problem is?
Thank you.
Quote:...It still beeps when a button is pressed, but no display... Would it Bake or Broil if you choose it? Gene.
Originally Posted by: Gene Would it Bake or Broil if you choose it?
Gene. No. The buttons still beep, but no visual. The ovens do not warm up. There seems to be an audible code of some kind. Three beeps when you try to heat the oven.
