Everything was working,power,gas...but now the dryer wont start. There are no codes displayed, lint filter is clean,sensors are clean(used white vinegar) but still nothing. It sounds like 2 clicks coming from the dial area when i push start. Can You please help??
Hi Racks
If you look on this Forum you will see very few Bosch questions answer, I think because few of us (certainly myself) have experience on these machines.
I suggest you try a different Forum and see if you have better luck.
Good luck, sorry we could not have been of much help
I have exact same problem.. seems to be the motor
Originally Posted by: ndfall@aol.com ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I have exact same problem.. seems to be the motor the problem was a faulty broken belt switch. Open dryer from the back, switch is on bottom left side. It is white and has a black arm with a spring on it. It is a safety feature that, in the event the belt breaks, the dryer will shut off. My belt wasnt broke, so i pushed the arm to the right, tried the dryer and it worked fine!!!
Originally Posted by: sidfink43 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Hi Racks
Good luck, sorry we could not have been of much help The problem was a faulty belt sensor switch. Bosch was VERY un-helpful.
Glad you got it fixed and thanks for the update. I am sure that will help others who post on the Forum
Bosch is not known for customer friendly attitude, another reason why their sales are not very high in this country.
