bigdavetru@yahoo.com
#1 Posted : Sunday, February 3, 2008 3:54:21 AM(UTC)
I'm working on a Whirpool dryer that runs but doesn't heat. Removed the burner assembly and everything on it checks out Ok. What should I check next? Thanks:)
here's the parts manual:
http://shared.whirlpoolc...20List%20-%204377829.pdf
#2 Posted : Tuesday, February 5, 2008 4:34:32 PM(UTC)
I think I should next test the thermal fuse. Can anyone look at the manual ( http://shared.whirlpoolc...20List%20-%204377829.pdf ) and tell me how to get to it. I'm a novice and I don't know whether if it's in the front or back! I guess you have to remove the blower housing . I just bought a multi-tester. I guess I should just test whether the fuse has continuity or not ( If I figure how to get to it! :confused: ).
