dwoutersz
#1 Posted : Monday, October 12, 2009 10:56:12 AM(UTC)
dwoutersz
Washer makes loud bearing noise in spin cycle. Everything else works fine without any noise. It does not leak.
sidfink43
#2 Posted : Wednesday, October 14, 2009 5:16:34 AM(UTC)
sidfink43
See if this technical bulletin from Maytag on your model addresses your problem.
http://www.servicematters.com/m...rary/docs/TDL-0060-B.pdf
It is a somewhat time consuming repair and you need special tools.
LI Mark
#3 Posted : Friday, July 15, 2011 6:15:09 PM(UTC)
LI Mark
I have the same problem, Tech Bulletin page has moved do you know where it is?
1st problem is the drive belt burnt at the small pully side and broke from a freeze up or something.
Put a ribbed type auto belt on that we matched to see if the tranny blew or if it still spins. It spins and agatates. Does full wash cycle - wash, rinse, spin.
Now getting Very Loud screeching when it starts to spin and continues until it reaches full speed - then gone.
Also If I put some pressure pushing the motor back is is not as loud, still screeches but reaches full speed quicker
Brakes fine and quiet.
Machine has a metal drive pully and it Sounds like metal on metal at the bottom of machine.
No metal filings under the machine.
Occosional burst of the same screech during wash / agatate/ rinse cycle.
Completes full wash cycle and runs pretty good but the screeching sounds like it's gonna blow up!
Helpl I want to fix it, 20 years new and counting.
Thanks.
