sacto
#1 Posted : Monday, October 12, 2009 7:44:26 AM(UTC)
sacto
My washer goes through it's complete cycle but does not empty or spin at the end. This happens only on the Permanent press and Delicate cycles. On the Regular cycle it does the whole cycle including empting and spinning.
Could this be a timer problem? What are the other possiblities?
Rick
#2 Posted : Monday, October 12, 2009 7:22:42 PM(UTC)
Very likely the problem is a bad timer. The model number you posted does not come up. Verify and repost it.
sacto
#3 Posted : Tuesday, October 13, 2009 7:24:55 AM(UTC)
sacto
I double checked the model number. It is LNC 6532 A 80. It is an old washer and many sites do not list the number. The only site I found that had a listing by the model number was the ************************.com.
Thanks for your reply. Any other thoughts???
Rick
#4 Posted : Tuesday, October 13, 2009 4:32:04 PM(UTC)
Check the original timer for any numbers on it and post them all. We'll try to find the replacement part.
Guest (4)
