Hi
My samsung washer will turn on when I press power but then it appears that all the buttons are frozen including the power button - the only way in which I can turn it off is to switch it off at the wall.
Any suggestions gratefully received - is it a simple problem or does it require a new control panel? if so, am I better getting a new machine?
Many Thanks
Please check your model number as what you posted does not seem to be correct. Not sure we can help since those who reply on this site including myself do not have a lot of experience on this brand, but lets see what model you have and maybe we can help.
