richardrbailey
#1 Posted : Monday, October 12, 2009 4:36:23 AM(UTC)
richardrbailey
I own a Whirlpool type 832, model WFW8500SR01 and it will not power on. I checked the electrical service at the plug and it works fine. I also disconnected, unplugged, the washer from electrical plug, and then reconnected it to "reset" the controls and still cannot turn it on. What suggestions on what to check?
I took off the top but I can't figure out how to expose the power switch wiring harness.
sidfink43
#2 Posted : Tuesday, October 13, 2009 2:53:20 PM(UTC)
sidfink43
Here is the service manual which should help you out.
Good luck.
https://secured.whirlpoo...61b1ba/$FILE/8178558.pdf
richardrbailey
#3 Posted : Tuesday, October 13, 2009 4:40:59 PM(UTC)
richardrbailey
The service manual helps. I can diagnose problem and easily order parts,
Dick Bailey
sidfink43
#4 Posted : Tuesday, October 13, 2009 5:43:41 PM(UTC)
sidfink43
Great, let us know if you need any help
Guest (5)
