jstutz101
#1 Posted : Monday, October 12, 2009 3:27:40 AM(UTC)
jstutz101
The title says it all. The light are on and the fans are running but the compressor is doing nothing at all. Any ideas??
I am guessing a bad circuit board since the compressor just quit without any warning. I am going to get the meter out and check the compressor next. Thanks for the advice I have found so far, this a great resource!
Jeff
jstutz101
#2 Posted : Monday, October 12, 2009 3:47:27 AM(UTC)
jstutz101
Just tested the compressor with a meter and it tests good. 0 ohms between the three posts on the compressor and NO continuity to ground. Circuit Board?
jstutz101
#3 Posted : Monday, October 12, 2009 4:22:48 AM(UTC)
jstutz101
One more tid bit of information - I tested the voltage at the compressor when the frige is on and get 0 Volts. Hoping its the circuit board!
jstutz101
#4 Posted : Tuesday, October 13, 2009 4:41:17 PM(UTC)
jstutz101
Replaced the circuit board and now back in action. Thanks to Appliance Part Pros for the quick delivery!!
