3 Pages<123
magician59
#21 Posted : Saturday, October 10, 2009 3:36:08 PM(UTC)
magician59
sorry: I've been very busy home schooling my son. I have a feeling you won't see an improvement until you proceed as suggested above. Everything needs to be in its proper place. Are you anywhere near Houston, TX, by any chance?
cskadavil
#22 Posted : Saturday, October 10, 2009 8:33:29 PM(UTC)
cskadavil
Yes, I am.
Thanks for response.
cskadavil
magician59
#23 Posted : Monday, October 12, 2009 4:21:37 AM(UTC)
magician59
Give me a call. 713 367 9943. Maybe we can look at it together. I'm in Tomball.
Fixer77
#24 Posted : Tuesday, October 27, 2009 5:57:23 AM(UTC)
Fixer77
Hello. Greetings. I new here. I have been reading this thread and it seems to be same problem that I have. I have a Maytag lat9766aae with the same noise problem. I wanted to open the front panel but I do not see any screws. Can you help? Thanks.
Fixer77
#25 Posted : Tuesday, October 27, 2009 9:51:07 AM(UTC)
Fixer77
I got lucky, I grabbed the bottom of the front panel and pulled it forward and it just popped open.
cskadavil
#26 Posted : Tuesday, October 27, 2009 2:39:19 PM(UTC)
cskadavil
there are no screws, just pry open the front, and snap close.
Fixer77
#27 Posted : Monday, November 2, 2009 5:12:47 AM(UTC)
Fixer77
I changed the mounting stem and tub bearing. Still have the high pitched terrible sound. I bet it is from the rear bearing and or the other bearing below it. Is this a tough fix? Can I just buy the bearings, the brake tool. Pull the old bearings out and replace? For the meantime, can you just grease the bearings? Thanks.
cskadavil
#28 Posted : Monday, November 2, 2009 3:53:32 PM(UTC)
cskadavil
I have done what you did, replaced
AP4372971 (6-2040130) Tub bearing kit
AP4390013 (6-2095720) Mounting stem repair kit
The leak stopped completely.
The high pitch sound at spin cycle is still there.
If you find any luck, let me know.
Fixer77
#29 Posted : Tuesday, November 3, 2009 3:40:52 AM(UTC)
Fixer77
Can you remove the brake another way without having to buy the tool?
Guest (5)
3 Pages<123
