donerite44
#1 Posted : Friday, October 9, 2009 12:08:16 PM(UTC)
donerite44
I noticed water on the floor, checked the freezer and found it warm. I checked the fan at the compressor and found it working. I checked the fan in the freezer and it was not working. After leaving the doors open for about 30 minutes I noticed that the fan in the freezer started to run. The freezer seemed to be cooling. I pushed it back in place and kept checking it. After about an hour after I last checked it I found the fan to be off again and the freezer not cooling.
#2 Posted : Saturday, October 10, 2009 2:02:50 AM(UTC)
Seems like a bad motherboard, AP4436216. Before replacing, check the back of the board for bad solder connections at the power relay area.
Refrig and Freezer not Cooling (Refrigerator & Freezer Repair)
by RBazela 11/20/2011 8:17:35 AM(UTC)
refrig and freezer not cooling (Refrigerator & Freezer Repair)
by gwaldron 6/14/2011 12:01:25 PM(UTC)
