jacktrouble
#1 Posted : Friday, October 9, 2009 2:08:33 PM(UTC)
jacktrouble
I have a range with a digital timer/clock display. The second digit over is not working properly. For example the 7 looks like a 1-a 0 looks like a U. The top LED on that digit is not working. The question is if I can replace the board or if I need a whole new clock for my model. Thanks.
#2 Posted : Friday, October 9, 2009 3:17:43 PM(UTC)
The control board aka a clock/timer. In other word this is the same part.
If you need the correct part number then post the serial number of the range and the color of the key pad.
Here are the breakdown diagrams and Replacement parts for CROSLEY C31113WAV | AppliancePartsPros.com
jacktrouble
#3 Posted : Friday, October 9, 2009 3:27:46 PM(UTC)
jacktrouble
Serial # 45630585cc
#4 Posted : Friday, October 9, 2009 3:40:45 PM(UTC)
What about the color of the key pad?
jacktrouble
#5 Posted : Friday, October 9, 2009 3:46:13 PM(UTC)
jacktrouble
Keypad is white.
#6 Posted : Friday, October 9, 2009 3:57:26 PM(UTC)
The clock Part number: AP4097071
You may want to talk to the APP customer service regarding the part ETA.
jacktrouble
#7 Posted : Friday, October 9, 2009 5:15:10 PM(UTC)
jacktrouble
Thanks for your help. Have a good evening.
