innovatech
#1 Posted : Thursday, October 25, 2007 8:44:53 AM(UTC)
innovatech
My Dacor MCS230S lower oven is not heating. Neither the main element nor broiler will heat. The controller shows that it is on and I can hear a relay clicking on and off. I removed the thermal switch because it did not appear to be resetable with the red button in front. When I test the switch it shows that the terminals are shorted so this may not be the problem. Any thoughts on what else could be the problem?
brandy9
#2 Posted : Friday, October 9, 2009 2:20:03 PM(UTC)
brandy9
I have had the same problem...replace the HTC switch and the lower oven still not not heat:mad:
