bobg7
#1 Posted : Friday, February 1, 2008 8:24:10 AM(UTC)
bobg7
When trash compactor is running it will make a loud clanking or clicking sound. in both the up and down position.
#2 Posted : Friday, February 1, 2008 1:20:33 PM(UTC)
When it switching from "down" to "up" - some clicking sound is normal.
Most likely it needs a maintenance and/or lubrication.
For more accurate advise I need the complete model number of the unit.
bobg7
#3 Posted : Saturday, February 2, 2008 6:40:12 AM(UTC)
bobg7
Model NO. is TC407
#4 Posted : Saturday, February 2, 2008 7:57:52 AM(UTC)
Remove the trash compactor from the cabinet.
Remove the drawer from the unit.
Remove one screw located under each corner of the control panel on the front of the unit.
Push the control panel upward and pull gently away to release two hooks from their slots on the unit frame.
Remove all screws holding the top cover and remove the top cover.
Lubricate the power nuts (#12 on the power screw & ram break down diagram) and the power screws (#1 on the power screw & ram break down diagram) using multipurpose lithium grease.
- Here are the break down diagrams for the Jenn Air trash compactor Model TC407B
bobg7
#5 Posted : Sunday, February 3, 2008 10:09:39 AM(UTC)
bobg7
This is one of the best sites I haver been to. Gene, You have saved me from buying a new one. The Jennair Site was useless. Keep up the good work. People like you make this a better place to live in this great country.
Semper Fi
Bob Greenburg:)
Guest (5)
jenn air trash compactor sticks (Trash Compactor Repair)
by rbern007 10/8/2007 10:49:35 AM(UTC)
