paul2112
#1 Posted : Friday, February 1, 2008 6:37:54 AM(UTC)
paul2112
Hello, we have a Maytag gas stove. The front 2 burners will not ignite(there is gas present just no spark) (the rear 2 burners work fine) and was told it was the ignition harness( around $200 repair quote). Looking at a diagram it shows an igniter, igniter switch, and spark module. Which of these would it possible be.. any help is appreciated..Paul
#2 Posted : Friday, February 1, 2008 11:54:01 AM(UTC)
Hi Paul,
Did you see any spark (maybe very weak) or hear any clicking noise when you turn on any of the front burners?
Visually inspect the ceramic part of the burner igniters for any crack or breakage.
Post your findings, please.
paul2112
#3 Posted : Saturday, February 2, 2008 3:09:23 PM(UTC)
paul2112
Yes on one of the burners I can see a faint spark and on outside of one burner and a faint spark on the inside of the other...Thanks again
Maytag Gas Stove Control Panel Dead (Oven Repair (including Ranges and Cooktops))
by bullcitybob 1/1/2014 12:45:27 PM(UTC)
Maytag Gas Stove (Oven Repair (including Ranges and Cooktops))
by fourparkinson 11/10/2010 1:06:59 PM(UTC)
by KATHA53 10/3/2009 11:35:44 AM(UTC)
