lhensley
#1 Posted : Friday, February 1, 2008 10:07:29 AM(UTC)
lhensley
Last night I used the Self cleaning option on my Whirlpool oven and this morning discovered that neither the oven or broiler wouldn't heat. The display works fine and when you try to turn on the oven it displays and sounds like it is working but isn't. Any suggestions on what I need to do to try and fix this myself.:confused:
misterfixall
#2 Posted : Friday, February 1, 2008 10:20:41 AM(UTC)
misterfixall
have you tried unplugging stove for a minute +replugging +press cancel
fyxer
#3 Posted : Friday, February 1, 2008 10:23:26 AM(UTC)
fyxer
Self cleaning your oven calls for high temperature over 600 degrees and depending on how long you clean it for your element takes a beating, i think your element might be burnt out, this happens quite often,your oven is an electric,but on gas ovens the ignitor also burns out sometimes after self cleaning.
sharzaz
#4 Posted : Monday, February 4, 2008 5:24:42 PM(UTC)
sharzaz
My frigidaire electric oven(3yrs old)is not working also after clean mode .Both element read about .13 ohms with wires disconnected.Also , when power on,switch on, tester probes on each end of element = no voltage. This condition for both top and bottom elements.Is there a in-line fuse ? Could this have burned out ? What does it look like ?
