SandyV48
#1 Posted : Thursday, October 8, 2009 6:31:09 AM(UTC)
SandyV48
Woke up with oil leak on floor. Motor?
#2 Posted : Thursday, October 8, 2009 6:45:59 AM(UTC)
Your Model Number is incorrect, please check it.
The only thing with oil in it, in a fridge is the motor.
So if it came from the fridge you have a major problem.
I would shut off the unit till you can determine the source.
SandyV48
#3 Posted : Thursday, October 8, 2009 7:38:47 AM(UTC)
SandyV48
Label inside door is Model 253-73754302.
Thanks. I am sure it's MAJOR!
SandyV48
#4 Posted : Thursday, October 8, 2009 7:43:55 AM(UTC)
SandyV48
Model Sears Kenmore 253-73754302. No motor shown in the schematic. I suspect going to get a new refrig shortly.
Thanks!
#5 Posted : Thursday, October 8, 2009 9:52:47 AM(UTC)
You had said motor so I used the same terminology actually it is an oil filled compressor.
Scadaboy
#6 Posted : Thursday, October 8, 2009 11:06:28 AM(UTC)
Scadaboy
It is possible your compressor is overheating and the shell is oozing its bonding/sealing gasket material becaue of the heat. The lubricating oil could also be leaking out a bad gasket. It is either failing on its own, or a continuous call for cooling (stuck thermostat or dirty coils) is making it run too much. There is usually a thermal limit switch built in to the compressor which is likely bad in addition to the other things. (This would allow it overheat).
Guest (4)
