AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Whirlpool AWM 328 washing machine wont go through cycle
This has been stood in the garage for about a year, It was working fine when it was stored, but now when i have come to power it up and run it...
1: i swtch on... set it on program 1 2: Set the temp and Spin 3: Press Start
when i have started it it takes in a little bit of water then just stops.
on other programs just does the same
ANy help would be appreciated
Thank you
I cannot get this model to come up, and have not worked on it but your symptoms sound like a lid switch or door/out of balance switch got stuck while it was in storage.
Check em out
Washer Repair
