badtothebone
#1 Posted : Wednesday, October 7, 2009 12:52:31 PM(UTC)
badtothebone
About a week ago, my dryer continued to spin when I opened the door. Now, the dryer won't turn on at all. Can you please assist me in trying to diagnose the problem. THX.
#2 Posted : Thursday, October 8, 2009 4:46:15 AM(UTC)
Replacement parts for WHIRLPOOL LER6611LQ0 | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/d...0Sheet%20-%203979703.pdf
Sounds like the door switch has failed.
Remove it and check it with a meter.
Remember to mark where the wires go.
Only other possibility I can think of is that you had a short on one of the wires to the frame/case and that has now burned up opening the connection.
badtothebone
#3 Posted : Thursday, October 8, 2009 9:54:58 AM(UTC)
badtothebone
I changed the door switch and the fuse. Still won't work.
#4 Posted : Thursday, October 8, 2009 1:44:43 PM(UTC)
Did you check the old switch and fuse with a meter.
A meter will come in handy in trying to figure this one out.
badtothebone
#5 Posted : Monday, October 12, 2009 10:39:05 AM(UTC)
badtothebone
The dryer will work after changing switch and fuse. However, the outlet seems to be bad. Thanks for your assistance.
