I need a new turntable motor for my Sharp microwave. Here is the specs on the one that is installed.
SM16 FY26M2H3 p/n RMOTDA252WRZZ, superceded by RMOTDA264WRZZ 120V, 60Hz, 3 RPM, 2.1W
I've found an exact p/n replacement for $26, but there is one on ebay that has similar specs. Here are the details.
ST16 KX63MPAQ p/n RMOTDA211WREO 120V, 60Hz, 3 RPM, 2 W
My thinking is as long as the shaft matches up with my turntable and the wattage is at or less than the original, then I should be okay right?
Gene:
My turntable doesn't work. It tries to turn but won't and makes a strange noise. I override it by turning it off, but do I need to replace the motor? Is is something I can do?
Thank you for your help.
