Kitchen Aid double oven door would not unlock after self cleaning. Sears service replaced Thermal sensor. Now oven will not heat. Sears wants to install new Control panel $465.00. Your service has this part on back order with no stock listed any time soon. Internet has this as a very common problem, but cannot find solution. Some sites state to replace thermal fuse,but your on line tech support says this model does not have a fuse. Can you offer some help? Thanks
THIS FORUM IS DEAD!!!!!!! |
Do you think a "thermal Cut Off" can be replaced. Thank you for the service manual. The top oven works fine, but with the holidays coming I really need both ovens. Thanks
Yes it can be replaced but first you have to find out if it is causing the problem. |
Thank you so much. Sears service replaced the Thermal control and I am up and cooking! Very helpful
