Washer Wont Stop Filling, Even When Unplugged Or Turned Off
Hi Denise, Most likely the problem with your washer is a stuck water inlet valve. - The part number for the water inlet valve is AP3861119 Here are the break down diagrams for the Hotpoint washer Model VBXR1070W2WWGene.
