2 Pages12>
jmontgo
#1 Posted : 17 years ago
jmontgo
I can't get the lower front panel loose. There are two clips on the bottom of the panel, but I can't get them loose.
#2 Posted : 17 years ago
In order to provide the most accurate advise I need the complete model number of the dryer.
jmontgo
#3 Posted : 17 years ago
jmontgo
this dryer is a kitchen aid, 12+ years old, mod # keyw777bwh2.
#4 Posted : 17 years ago
Using a putty knife, push the spring retainer (#43 on the cabinet parts break down diagram) on each side of the bottom panel in and down to release it.
jmontgo
#5 Posted : 17 years ago
jmontgo
Thx, I'll give it a try.
jmontgo
#6 Posted : 17 years ago
jmontgo
Here's some more info on the problem. The dryer will turn on after about two or three hours after it quits. It will run for about three or four minutes, then start to click and then turn off. The drum will turn by hand when the dryer is off and doesn't sound bad or feel difficult to turn. Any ideas as to what is wrong or what to look at? Could there be a faulty overload or thermal switch? Appreciate any comments.
#7 Posted : 17 years ago
Sounds like the motor gone bad.
jmontgo
#8 Posted : 17 years ago
jmontgo
Today, I opened the lower front panel, looked at the rollers and drive belt, they all appear to be ok. I turned the time on to 20 minutes and closed the door and the ddryer started without pushing the start button. It ran for the full 20 minutes. When I opened the door while it was running, it stopped, when I closed the door, it started again without pushing the start button. I tried to hold the drum and closed the door. The dryed tried to start for a few seconds and then the motor shutdown and wouldn't start again for a few minutes with the door closed, then it started all by itself. Still think its the motor? Would I get open circuit readings on the ohm meter if the motor is bad?
#9 Posted : 17 years ago
Now it looks like there are two problems: the start switch and the motor.
- The part number for the start switch is AP3037944
- The part number for the motor is AP3094245
Here are the break down diagrams for the Kitchen Aid dryer Model KEYW777BWH2
jmontgo
#10 Posted : 17 years ago
jmontgo
Do we have to remove the drum to get the motor out? Looks like the top panel and the the control panel all have to come out.
Another thing I noticed was the front seal bearing has about a 1/2 inch play in it . Is this ok or should it be replaced also?
2 Pages12>
