mishdeme
#1 Posted : 17 years ago
mishdeme
We've replaced the thermal cutoff and the hi limit thermostat. The dryer still runs but with no heat. Any other suggestions????? I'm about to throw in the towel and call for service. I'm tired of hanging clothes to dry.
mishdeme
#2 Posted : 17 years ago
mishdeme
Bumping for help please
misterfixall
#3 Posted : 17 years ago
misterfixall
is this model electric ,if so did you check heater, did you check for 220 volts coming to dryer outlet. could even be timer problem
mishdeme
#4 Posted : 17 years ago
mishdeme
Found the issue. The circuit breaker was tripped after the fuses blew. It looked like it was on but after flipping it a few times it reset. Thanks for the help
