I would like some detailed instructions about the removal of the water pump for this machine.
I've read some of the posts on this problem and think that this is the problem with my machine.
Recently it has started making a kind of grinding noise and the clothes are still quite wet at the end of the rinse cycle.
Any help on this would be much appreciated.
What is the complete model number of the washer?
It's the Maytag Performa Oversized Capacity Plus PAV-1
PAV-1 is not a model number. Look for the name plate with the model number on top of the control panel.
I believe this is it PAV1000AW
