happ racer
#1 Posted : Tuesday, October 6, 2009 2:17:28 PM(UTC)
happ racer
Hello, An explanation of the motor switch function and operation would be appreciated. This is the connector/switch that is actually on the drive motor itself. Does this switch reverse the motor?
happ racer
sidfink43
#2 Posted : Wednesday, October 7, 2009 5:20:29 AM(UTC)
sidfink43
Hi Happ
On your model your motor has both start windings and run windings. When the machine first starts the start windings are powered to get the machine going. After the motor is running, the switch will turn off the start windings and the motor will run on the run windings.
If you have a multiple speed motor the motor switch will also be used to select the speed of the motor.
Hope this helps.
