AppliancePartsPros.com
Appliance Repair Help
Washer Repair
When I Turn My Machine On It Wont Start And Is Saying E3???? Can You Help Me Fix This
I Have Tried To Use My Washing Machine But Wen I Turn It On It Fills For A Coupleof Seconds Then Its Saying Error Code E3 Plesae Can You Help !!!!!!!!!!!!!!!!!! Thank You
From a manual: Display “E3” Evaluate wire harness for loose or unhooked connections. If machine has separate motor control, perform self diagnostic motor test. See “Board Output Test”
Board Output Test While in Service Mode*, pressing the Spin Speed key will begin the Board Output Test. This test turns on a specified output after a key press. Pressing the Spin Speed key again cancels the test. Only one output can be “on” at any time. All outputs will be turned off after five (5) minutes of inactivity. While in Service Mode follow to check respective function. • When the “Rotary Cycle Selector” is set to “Super Wash” and the “Rotary Cycle • Selector” button is pressed, the Main relay will be toggled (either from “on” to “off” or from“ off” to “on”). • When the “Rotary Cycle Selector” is set to “Normal” and the “Rotary Cycle Selector” button is pressed, the hot water valve will be turned on. This output will remain on until the “Rotary Cycle Selector” button is pressed again to turn off the output. The control will not allow the machine to fill past the High water level. • When the “Rotary Cycle Selector” is set to “Wrinkle Control” and the “Rotary Cycle Selector” button is pressed, the cold water valve will be turned on. This output will remain on until the “Rotary Cycle Selector” button is pressed again to turn off the output. The control will not allow the machine to fill past the High water level. • When the “Rotary Cycle Selector” is set to “Delicates” and the “Rotary Cycle Selector” button is pressed, the bleach valve will be turned on. This output will remain on until the “Rotary Cycle Selector” button is pressed again to turn off the output. The control will not allow the machine to fill past the High water level. • When the “Rotary Cycle Selector” is set to “Hand Wash” and the “Rotary Cycle Selector” button is pressed, the pre wash valve will be turned on. This output will remain on until the “Rotary Cycle Selector” button is pressed again to turn off the output. The control will not allow the machine to fill past the High water level. • When the “Rotary Cycle Selector” is set to “Quick Wash” and the “Rotary Cycle Selector” button is pressed, the drain pump will be turned on. This output will remain on until the “Rotary Cycle Selector” button is pressed again to turn off the output. • Pressing the “Delay” switch pad will turn on the motor and the “Delay” LED. This output and the LED will remain on until the “Delay” switch pad is pressed again to turn off the output. When activated, the machine will tumble for 5 seconds in the CW direction, pause for 2seconds, tumble in the CCW direction for 5 seconds, pause for 2 seconds; repeating this pattern until “ Delay” button is pressed again to turn off the tumbling. Note that all tumble speeds are assumed to be 45 rpm. • Pressing the “Chime” switch pad will unlock the door and turn on the all the LED’s above the “Chime” button. This output will attempt to unlock one time, if safe to do so. • Pressing the “Temperature” switch pad will lock the door and all the Temperature LED’s will turn ON. Pressing the “Chime” button will unlock the door and the all the Chime LED’s will turn ON. • When the “Rotary Cycle Selector” is set to “Colors” and the “Rotary Cycle Selector” is pressed, the bleach valve and the cold water valve will be turned on to check the fabric softener fill. This output will remain on until the “Rotary Cycle Selector” button is pressed again to turn off the output. The control will not allow the machine to fill past the High water level. • When the “Rinse & Spin” keypad is pressed, the Heater will be turned on if the water level is above the Heater Safety Level. If the water level is below the Heater Safety Level, a warning beep will be given and the heater will not be turned on. The Heater output will remain on until the “Rinse & Spin” keypad is pressed again to turn off the output. *service mode: To enter Service Mode press the Chime and Extra Rinse keys for three seconds or until the control beeps. NOTE: The washer must be on before Service Mode can be entered. The motor speed will be displayed when started (motor not running display will be 0). The present state of the machine will not be changed (i.e., the current cycle in progress will not be interrupted and only the display will change). All LED’s will be turned off except the “Door Lock” LED. It will continue to display the condition of the door lock. To exit: 1) Press Chime and Extra Rinse keys for 3 seconds again, or 2) Press Off, or 3) Unplug the machine. Pressing the Rotary Selector knob while running a test will pause the individual test, while remaining in Service Mode. The following table summarizes special tests and features available in Service Mode, along with methods of activation and cancellation. Simple ain't it?:D Houston we has a problema!!:D
Washer Repair
