buffalobills
#1 Posted : Monday, August 13, 2007 7:23:19 PM(UTC)
buffalobills
Hello are there many diffrent part numbers for admiral timer i need to buy this part and i need to know if there are many diffrent part number to look for like a maytag part number or admiral part number or just a sears number please help thanks :eek:
ApplianceJunk
#2 Posted : Tuesday, August 14, 2007 4:36:37 AM(UTC)
ApplianceJunk
Lets start with the brand and model number of the appliance.
If it's a sears the sears we should be able to find it from the sears model number.
buffalobills
#3 Posted : Tuesday, August 14, 2007 5:38:20 AM(UTC)
buffalobills
Hello here is the brand admiral Lnc6757a71 what i am looking for is the timer and to see if there are diffrent parts number to shop around for the less cost. i now that maytg makes alot of the same parts and call them diffrent part numbers
buffalobills
#4 Posted : Tuesday, August 14, 2007 8:22:23 AM(UTC)
buffalobills
Hello i have ADMIRAL washer item number lnc6757a71 when i turn the washer on it will fill with water and start working then it go all the way to spin and will not drain water it just is on hold not doing anything. if i push the start button in and spin it around to spin and pull the nob out it will drain and spin but it will not fill with water to run the rinse. but if push the button in and spin the nob to rinse it will fill with water and run but wont drain. i can push in the nob and spin the nob to spin and it will drain and spin to finish please help i think it is the timer is bad Please help
Admin / APP Team
#5 Posted : Tuesday, August 14, 2007 8:51:57 AM(UTC)
Admin / APP Team
Rank: Administration
This timer should be the right one for LNC6757A71. If you'd like to confirm, get the part number off the old timer and enter it here.
