marty1
#1 Posted : Thursday, January 31, 2008 12:11:26 PM(UTC)
marty1
At first Ice maker not working then water leaking at ice maker side. I shut off value at water supply. 1 month later ice build up in bottom of freezer with water leaking under refig. Is this fixable or is time for replacement, or would a service call do, no warranty:confused:
misterfixall
#2 Posted : Thursday, January 31, 2008 12:49:57 PM(UTC)
misterfixall
possibly there is problem with icemaker water valve not completly closing when there is no power going to it sent by icemaker, or it could be the water feed tube going into ice maker tray has come away. if this is not problem perhaps drain hole going down to drain pan is blocked at bottom of freezer behind panel
