HOW DO U REPLACE RUBBER SEAL AROUND DOOR.AND WHERE CAN U FIND IT.:confused:
If you open the door and look under the door seal you will see the screws that hold it in place.
I have found it is best to take the door off and find someplace you can lay it flat to work on it.
For example on a table with the door handle hanging over the edge.
If you do not have it laying flat the door will tend to twist on you as you take it apart.
You do not have to remove the door gasket screws all the way, just losen them up enough to pull the old gasket out and then slip the new one in.
Just click on the model number on top your first post to find the correct door gasket for that model.
Originally Posted by: stanley  HOW DO U REPLACE RUBBER SEAL AROUND DOOR.AND WHERE CAN U FIND IT.:confused: NEED TO REPAIR RUBBER SEAL AROUND REFRIGERATOR DOOR
