bmaroney
#1 Posted : Sunday, September 23, 2007 12:06:48 PM(UTC)
bmaroney
My Kenmore dishwasher has a blinking clean lite. Seven blinks, heater problen. When i push start button blinks red and it does not start. The heater circuit checks out with an ohm meter, Door switchs check out ok. Must be the control board. Any help would be nice Cheers
#2 Posted : Wednesday, October 3, 2007 7:42:22 PM(UTC)
Hi bmaroney
Did you check both the heater and the thermostat?
Did you check wires?
If your answer yes then the problem is a bad control board.
Post the complete model number and I can find the right part number for you.
Robertbu
#3 Posted : Friday, October 12, 2007 5:13:51 PM(UTC)
Robertbu
New to fourm did you find the problem with no start mine is doing the exact thing Model #66516029402 Ser # FTO308225
#4 Posted : Friday, October 12, 2007 5:18:40 PM(UTC)
Hi Robertbu
What exactly your dishwasher is doing? Post as much information as possible.
Robertbu
#5 Posted : Friday, October 12, 2007 5:27:55 PM(UTC)
Robertbu
The green light blinks 7 times then a pause. the cycle light light up when selected. press start nothing happens. after a while the cycle light goes out. have chech the door sw. both are working.
#6 Posted : Friday, October 12, 2007 5:43:24 PM(UTC)
The problem with your dishwasher is a bad heating circuit. You have to check for continuity the heat element and the safety thermostat. Also check all wires.
If you need the part number to replace the bad part let me know.
Good luck.
okbobcats
#7 Posted : Saturday, October 13, 2007 3:58:39 AM(UTC)
okbobcats
try pressing normalwash-heatdry-normalwash-heatdry-normalwash-heatdry-normalwash-heat then all the lights come on. Let run for a little bit. then keep pressing the start button. tell the unit shuts off, Your control board has a memory in it. So if you have cold water running in it one time. It will take longer to warm up. Your memory in the control board says its taking to long to warm up. Shutting down thinking their is something wrong with your heating cycle.
If it keeps happening you could have something wrong as Gene stated.
caste
#8 Posted : Thursday, January 31, 2008 7:37:40 AM(UTC)
caste
I have the same problem with a Kenmore Model 17362301. Clean light flashing 7 times, cancel will pump out, tried shutting off power to clear but to no avail.
I cannot get it to enter the diagnostics program. It does not have entry keys as described. The keys on the panel are: smart wash, pots pans, normal wash, quick rinse, hi temp wash, sani rinse, air dry. What is the sequence for entering diagnostics?
:confused:
Guest (5)
