candypwhite
#1 Posted : Monday, October 5, 2009 11:48:40 AM(UTC)
candypwhite
I have a GE Profile side y side Artica. The ice maker stop making enough ice to fill tray and water is leaking where the ice tray meets teh back and causing a thick layer of ice on food and down back inside freezer. Ice also is not solid - looks like it is melting. Rest according to instruction - you know the 15 seconds, and push the paddle 3 times. i say a little water come out of the disper int he back, but it was just a little. Trays seems to be full of water, but again, small amount of ice being created - I have more ice on the back of the ffreezer than in the tray. Any ideas what to do?:eek:
applianceman
#2 Posted : Monday, October 5, 2009 5:11:35 PM(UTC)
applianceman
Typically what will cause this is the fill tube will clog with ice causing water to spray everywhere. Look at the tube that fills the icemaker with water and if it is clogged with ice remove the ice and replace the water valve. Refrigerator repair guide
