bconn13
#1 Posted : Friday, July 31, 2009 8:21:29 AM(UTC)
bconn13
I have a 4 burner gas Frigidaire Gallery Pro series range/oven. Until recently it worked perfectly, however 90% of the time only one range burner will light (back left). I hear clicking that seems slow and only comes out of the back left burner. I can light all burners with a match. The other 10% of the time all burners light, so it seems that something is going bad, my guess is the spark module. The clicking also seems quieter than it used to be. By reading some other posts it seems that the ignitors may also be the culprit.
How do I replace the module, my range is sealed and I am not sure how to get beneath it. Where is the module located?
Thanks in advance
magician59
#2 Posted : Friday, July 31, 2009 2:11:38 PM(UTC)
magician59
Replacement parts for FRIGIDAIRE FGF378WCCG | AppliancePartsPros.com
It looks from the drawing like you can remove the burner diffusers and ignitor electrodes to access the module by lifting the top. [COLOR="SandyBrown"]Do NOT attempt to lift the top without first removing ALL the diffusers.[/COLOR] This can kink the gas lines and cause a leak you can't afford to have.
ron kuhlman
#3 Posted : Sunday, October 4, 2009 1:28:03 PM(UTC)
ron kuhlman
Frigidaire Model # FGF379WECA - I have no sparks from the ignitors on the right side. I have tested current to the ignitor and there is current at the base of the ignitor. Are both ignitors bad? if so, how do I replace them? What are the other possibilities?
magician59
#4 Posted : Monday, October 5, 2009 7:30:26 AM(UTC)
magician59
Clean them with a wire brush first. Sometimes, that's all it takes.
