Oven fan goes on and will not turnoff. Advised that the entire clock unit needs to be replaced b/c cannot locate the "one" board that needs to be replaced. The cost of the entire clock unit and labor is almost as much as the cost of the wall oven. :confused:
Rank: Administration
Jake, can you post the model number?
Originally Posted by: jake  Oven fan goes on and will not turnoff. Advised that the entire clock unit needs to be replaced b/c cannot locate the "one" board that needs to be replaced. The cost of the entire clock unit and labor is almost as much as the cost of the wall oven. :confused: Model No. 12-4990-00/04
jake Unfortunately without the wiring diagram for your oven I can not tell you how the oven fan should work. I was unable to find the wiring diagram for this particular model. If, by any chance, you have it and you are able to post it, it will help a lot. Gene.
