bobafett
#1 Posted : Sunday, October 4, 2009 7:43:46 AM(UTC)
bobafett
Hello,
I have a 7 year old KitchenAid Superba which has worked fine until recently the ice machine stopped making ice. The water portion still pours out water. An image of the fridge water/ice dispenser is below:
UserPostedImage
I think the water inlet tube is frozen. I turned off the freezer/fridge (unplugged it) for a few hours. This didn't help the situation.
The copper water line into the back of the fridge is fine (it isn't frozen and isn't leaking). The fridge is functioning fine otherwise. The freezer switch inside the freezer is turned to the "On" position.
Then I thought I would check out water tube inside the freezer. In order to do this I removed the motor/ice tray:
UserPostedImage
The water tube is the black tube on the top right of this image.
The motor/ice tray component is here in case you are wondering and it appears fine although I haven't cracked the plastic case to inspect the motor yet:
UserPostedImage
I have inserted a blunt plastic straw instrument into the water line:
UserPostedImage
Wasn't sure how deep the straw should go in. I didn't want to force it so this is as far as I could insert it (my thumb marks the depth). I assume it should go in a lot further. There was a little bit of ice on the tip of the straw as I removed it.
UserPostedImage
I am assuming the problem is that the water line is frozen.
I have already turned off the fridge (unplugged it) for a few hours which didn't work. Any other ideas? Thinking about sticking a blowdryer on the hole for a while to see if the ice melts. Not too keen on chipping away inside with a sharp instrument (screwdriver?) as I do not want to damage it.
Any help would be greatly appreciated. Thanks
bobafett
#2 Posted : Sunday, October 4, 2009 3:13:01 PM(UTC)
bobafett
Btw my model number is: KSRA25FKSS00
UPDATE: so I used a hairdryer to melt some of the ice -- there wasn't that much ice so I am not sure if that was the problem. The water inlet tube (the black rubber component in the top right of the second image -- this part: Part Details - WHIRLPOOL Fitting, water tube, part number: AP3182503) is now ice free.
Interestingly, when it became ice free some icewind was blown into the freezer for a few seconds.
I reinserted the motor and I turned the ice machine "on".
Nothing has happened. I read somewhere that it takes 24 hours to refill the ice. So I guess I will wait 24 hours.
The techinician on this site:
Kitchenaid Refrigerator Stopped Making Ice
did the following:
"I started a harvest cycle which allowed me to visually see the ice maker operate mechanically and fill with water. "
I am not sure how to start a "harvest cycle" but I would like to know how!
sambino69
#3 Posted : Wednesday, October 7, 2009 11:25:05 PM(UTC)
sambino69
please let me know how it goes? i have same problem with mine too
OK,Talk to a friend of mine, he said the motor probably broken, he told me to check the white plastic teeth on the tray, if the teeth are not sticking up, replace the motor, pop the square white cap open,(pic no. 3) unscrew 4 screws and replace the motor.
