lanza530@comcast.net
#1 Posted : Wednesday, January 30, 2008 11:56:01 AM(UTC)
I would like a belt- pulley kit.also sensor that detects if clothes is not working.The dryer works fine on time dry.Do I need a sensor,if so please give me pats #s and prices for both items.
Thank you
#2 Posted : Thursday, January 31, 2008 11:09:07 AM(UTC)
Most likely the problem on auto dry cycle caused by an air flow restriction in the exhaust line.
Disconnect the vent hose on the back of the dryer and run couple loads without the vent hose. If you'll see a difference then the venting needs cleaning. Also check the blower and the air ducts inside the dryer.
- The part number for the belt is AP2946843
Here are the break down diagrams for the Whirlpool dryer Model LE9800XSW0
Tony Emmerson Microwave (Microwave Repair)
by carrieg 12/9/2011 12:29:29 PM(UTC)
Tony (Dryer Repair)
by SUPERCALIFRADULISTIC 12/2/2010 12:09:26 PM(UTC)
Tony in Ma. (Microwave Repair)
by butch194928 3/26/2010 6:34:48 AM(UTC)
