The part number is AP2150133 and along with the thermostat it has 2 wire connectors and 2 white sleeve pieces, what are these sleeves for. Are they insulators that cover the wire connectors? Also, do I need to use any sort of glue or liquid insulator to protect the wiring in the freezer? http://www.appliancepartspros.c...t_id=2150133&image=0
Quote:what are these sleeves for. Are they insulators that cover the wire connectors? Heat shrink tubing. Slip the sleeves over the wire. Crip the wires together and then slip the white heat shrink tubing over the connection. Heat the white tubing up with a heat gun, hair dryer or lighter to shrink it over the connection. Quote:Also, do I need to use any sort of glue or liquid insulator to protect the wiring in the freezer? No
I had a feeling it was for something like that. Thank you very much.
