Nic2009
#1 Posted : Sunday, October 4, 2009 5:55:42 AM(UTC)
Nic2009
The 'Haier' model's refrigeration compartment is only 45 or below when set to highest cold setting for refrigerator compartment and the freezer is set to it's coldest setting as well.
The unit seems to be acting as if it is freezing up for lack of refrigerant gas or some other cause. Ice build up, although not visually apparent for the unit is full of frozen food, causing interference (not the food) with the fan and the surrounding plastic back wall seems to be the source of the noise. Depressing the back wall of the freezer compartment on the left or right side about the location of the fan, sometimes suppresses the noise entirely, even when released (at times).
I have considered the thaw cycle or temperature not operating properly, but with the temperature in the refrigeration not tolerating warmer settings without the temperature rising to 55+ degrees; I more or less seem to doubt this as a likely scenario.
Additionally, re. the defrost cycle, there is no apparent interior build of ice within the freezer compartment at anytime.
I enjoy troubleshooting, but I am novice with some intermediate skill level, would anyone care to offer some other opinions or suggestions?
Here's some additional info on the Haier unit for it wasn't listed in the 'down-arrow menu' on this forum.
Thank you in advance for all your help, Nic:)
#2 Posted : Sunday, October 4, 2009 10:55:30 AM(UTC)
Cannot find any technical info on a Haier.
But it does sound like you have a defrost problem.
Only way to tell is to pull the evaporator coil cover and check them.
No defrost will not necessarily cause a buld up of ice/frost in the freezer compartment.
Here are a couple good sites with troubleshooting help
http://www.applianceaid.com/refrigerator.html
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
Nic2009
#3 Posted : Monday, October 5, 2009 12:26:59 PM(UTC)
Nic2009
Thank you Denman.
Would your thoughts towards defrost be the same if I said this condition was more than 8 months or better and ongoing? Or would you suspect anything else?
It may also be worth noting that the unit has some external damage to doors; the owner said it was reduced in price for this reason.
I am still considering your view, I was also wondering what values one might expect to find with the low or high pressure sides?
Thank you in advance.
#4 Posted : Monday, October 5, 2009 12:57:47 PM(UTC)
Yes it would make a difference. The unit will not defrost itself so if it was a defrost problem you eventually will loose most of the cooling in the unit.
Yes but not sure what.
Pull the cover off the evaporator coils and take a look, it can tell you a lot.
1. If the fan is not operating correctly it will not pull enough air through the coils to provide efficient cooling.
2. If they are heavily iced/frosted up then defrost could be the problem
3. If there is just frost/cooling where the freon from the compressor enters the coils then you may be low on freon. Can also be stotty cooling across the coils.
Check that the doors a sealing correctly.
take a dollar bill put it between the door seal and the units frame then pull it out. If it pulls out with no resistance the door is not sealing correctly. Work your way around both the freezer and fresh food doors.
No idea I do not have that info
Nic2009
#5 Posted : Sunday, November 28, 2010 9:57:10 PM(UTC)
Nic2009
Hi Denman:)
I was afraid to do too much because we were uncertain if a warranty applied at the time. As it turned out, a warranty was in effect and the unit supposedly could not be repaired and so a store credit was issued. I was told that Haier (made in Korea) and many other models that were made overseas were a bit of risk in terms of actually finding OEM parts. So if a unit was at some point in need of a repair, a universal part would essentially be your only alternative if even available.
As for what was wrong with the unit, the warranty repair services didn't do anything except note the brand say, 'Can't be fixed or get parts.'
I have heard that before and although that may be true in this case, at times I can still track down parts through my parts rep. that others tell me can't be had. I usually give tell them where they can it if I do find it. :)
Thanks again,
Nic:)
Thanks again and I am sorry for such a long delay in a follow up.
