charless2009
#1 Posted : Friday, October 2, 2009 8:25:18 PM(UTC)
charless2009
My refrigerator stopped cooling. The cooling system, including the fan keep booting up every 2 seconds, without success. It seems to have a bad capacitor per internet.? Since this is 2006 product, was capacitor placed in the compressor control board asm?
Please help. Thanks
#2 Posted : Saturday, October 3, 2009 2:25:19 AM(UTC)
Replacement parts for WHIRLPOOL GC5SHEXNB03 | AppliancePartsPros.com
Here is the tech sheet and a manual.
Note the manual is for a unit which should be close to youurs.
http://www.servicematters.com/d...0Sheet%20-%202223419.pdf
https://secured.whirlpoo...7aa82/$FILE/8178066A.pdf
You will see that your unit uses an inverter for the compressor.
The manual gives an explanation of how this works and how to check it.
This may be a job for a pro if you have no experience with electronics/electrical.
charless2009
#3 Posted : Saturday, October 3, 2009 4:26:20 AM(UTC)
charless2009
Originally Posted by: denman Go to Quoted Post
It must be it. The booting-up noise came from the inverter. You are a real pro! I will give a try. Thanks.
