The other night my wife was warming up something for dinner, she set the time and hit the start button. The microwave powered on for 2-3 seconds, made a pop noise followed by sparks coming out from underneath the unit. This is a electric oven/microwave overhead setup. The microwave would not turn back on, I checked the breaker to the oven/microwave and it was not tripped and the oven still operates.
I would prefer not to change the unit out, I didn't know if there was a fuse or maybe something simple to replace or check. Any help would be appreciated, thanks in advance!
Rank: Administration
Groups: Guests
MVP111 is what you see on the front of the microwave, the actual model number is inside on a small tag.
A loud pop usually indicates a failed diode.
