myron j.
#1 Posted : Thursday, October 1, 2009 11:30:35 AM(UTC)
myron j.
coil in the freezer froze up not allowing the air to cool the top part of the fridge. What part should I check first to solve this problem?
#2 Posted : Friday, October 2, 2009 3:39:09 AM(UTC)
Unit parts replacement parts for WHIRLPOOL GB2SHDXTQ00 | AppliancePartsPros.com
Here is the tech sheet
https://www.servicematters.com/d...0Sheet%20-%208208183.pdf
Try forcing the unit into a defrost cycle.
If it does defrost then the control board is probably shot.
If it does not defrost, it could be the defrost heater or the defrost thermostat.
Check them with a meter.
The heater should be approximately 30 ohms
The defrost thermostat should be closed (0 ohms) when frozen. Note it opens just above freezing.
You could also check that they are getting 120 volts in defrost mode.
Note if both the above check out OK then it is probably the board.
