GNACK
#1 Posted : Wednesday, September 30, 2009 7:17:12 PM(UTC)
GNACK
My Kitchen Aid diswasher has recently started to run for long periods of time (sometimes 2+ hours). I assume that the timer is burnt and need to know what is the appropriate part to purchase to rectify this problem. I am assuming that it is the control module that needs replacement? Please advise.
Thanks...
GN
#2 Posted : Thursday, October 1, 2009 1:55:37 AM(UTC)
Replacement parts for WHIRLPOOL KUDI01ILBL2 | AppliancePartsPros.com
Here is a tech sheet
http://www.servicematters.com/d...0Sheet%20-%208537797.pdf
Odds are that the board itself is OK.
Run the diagnostics.
Could be a problem with the water temperature/heater and the unit is waiting for the water to come up to temp. Check that the input water is at 120F.
Check that the heater, hi-limit thermostat and thermistor are OK.
May also be a problem with the soil sense and it is adding time to the wash.
Kitchen Aid Undercounter Dishwasher leaking out of air gap (Dishwasher Repair)
by Dan Dingess 10/24/2011 8:13:57 PM(UTC)
