The ice maker in my Frigidire makes ice fine but there is a slight leak at the rear and also the ice lumps up to the point you can't break it up to use it.It seems to be getting worse.
Any thoughts?
If the ice maker overfills and leaking over then the water inlet valve has to be replaced. If the ice maker itself is leaking then the the correction is to replace the ice maker. - The water valve Part number: AP2115552
